viernes, abril 10, 2026
trialero14 dijo:
Home Foros Foros Todotrial – Moto Foro General trialero14 dijo:
    • #82345
        Buenas, tengo una pregunta de reglamento. En una zona, a condición de no cruzar mi trazada, tengo derecho de pasar por las puertas del color de mi categoría en el orden que yo quiera ?
        Gracias de antemano.
      • #82346
          Pues excelente pregunta.
          Consultando el reglamento FIM, no veo ningún punto en que indique que las puertas marcadas con flechas tengan un orden secuencial establecido ni obligación de numerarse correlativamente. Ser es de sentido común, pero quizás por obvio, no se indica expresamente en el reglamento. (Mi opinión tras leerlo).
          d) ? Failure: 5 points
          Definition of Failure
          – The machine is moving backwards with or without the rider footing.
          – The machine touches the ground with the front or rear wheel, outside a
          boundary.
          – The rider or machine touches or rides over or above a marker or marker
          support before the front wheel spindle passes a ?section ends? sign (except
          for the situation described in Art. 052.4.2).
          – The rider dismounts from the machine and he has both feet on the
          ground, on the same side or behind the axle of the back wheel of the
          machine.
          – The hand of the rider leaves the handlebar and touches another part of his
          machine when he foots, whilst stationary.
          – The rider does not complete a section within the time limit.
          – The front wheel does not precede the back wheel when passing through a
          gate.
          – The rider enters the section by foot.
          – The rider receives outside assistance.
          – The rider or his assistant changes the condition of a section.
          – The rider passes through the gates of another category whatever the
          direction.
          – The assistant comes into the section without the invitation of the
          official.
          – Not entering a section, providing the rider has reported to the section
          official.
          – The engine of the machine stops whilst the rider is leaning or any part of the
          machine with the exception of the tyres, touches the ground, without forward
          motion.
          – The handlebar of the motorcycle touches the ground.
          – The motorcycle does a complete loop, crossing its own track with both
          wheels.
          All failures (motorcycle moves backwards, falls, does not respect the time limit,
          etc.) must be signalled by the Observer by an immediate whistle.
        • #82347
            No puedes pasar pr puertas de otra categoria que no sea la tuya en ningun sentido. Teniendo en cuenta eso, mas lo que apuntas no debiera haber problema. Generalmente, y dentro del reglamento, lo que expones no es posible salvo craso error en el diseno de la zona
          • #82348
              Como bien dices, sino cruzas la trazada puedes hacerlas en el orden que prefieras. Con el reglamento actual del Campeonato del Mundo, prácticamente todo el mundo las pasa en el mismo orden porque las zonas están marcadas de tal manera que hacerlo de otra forma sería más complicado. Con el reglamento Openfree es muy habitual ver a muchos pilotos hacer puertas en distinto orden.
            • #82349
                Por supuesto que no vale puerta de otra categoría y que el sentido de paso tiene que ser el indicado, pero eso SI se dice expresamente en el reglamento.
                – The front wheel does not precede the back wheel when passing through a gate.
                – The rider passes through the gates of another category whatever the direction.
                La duda de trialero14 es referente al orden de paso de las puertas y sobre esto, el reglamento no dice absolutamente nada.
