domingo, octubre 11, 2026
rafile dijo:
    • #179309
      Hola alguien me puede explicar como canviarle el aceite de las barras delanteras de una GG pro.Gracias y Saludos
    • #179310
      [font=Times New Roman]Hola.[/font]
      [font=Times New Roman]Mira aquí:http://todotrial.mforos.com/61182/6460823-ayuda-con-horquillas-de-pro/?marcar=liquido+horquillas%5B/font%5D
      [font=Times New Roman]o bien utiliza el buscador del foro, que encontrarás mucha información.[/font]
      [font=Times New Roman]Es algo parecido a esto: http://www.sherco.com/wayne/Sherco_Fork_Seal_Replacement.pdf%5B/font%5D
      [font=Times New Roman]Saludos.[/font]
    • #179311
      Hola rafile , te adjunto el texto de las instrucciones para el mantenimiento de las horquillas marzochi de Gasgas , desafortunadamente , esta en ingles.
      FRONT SUSPENSION MARZOCCHI 40mm. TRIAL PRO (2006) – 250, 280, 300cc.
      [font=Times New Roman]Please review this file with special attention being paid to this procedure. You will find the correct information related to the oil capacity on the Marzocchi front forks with aluminum upper legs. As you can see, GasGas Motos no longer recommends the replacement of the oil via the «capacity» method. There has been some problems relating to customers that do not remove completely the old oil. When the new oil is added, the result is a leg being overfilled. [/font]
      [font=Times New Roman] [/font]
      [font=Times New Roman]This is the reason why we now suggest to change the oil using the «measurement» method as we describe in this document. (The one that measure the empty space left between the oil and the top of the upper leg.) In addition, please notice that the right leg of the ’06 front forks, holds an internal cartridge, and depending on the oil left on this cartridge, the oil needed will change. [/font]
      [font=Times New Roman]The correct capacity is 230 cc. for the left leg and 130 cc. for the right one if each leg is completely dry. [/font]
      [font=Times New Roman]GasGas is certain that the best way to replace the oil on the forks is by using the procedure described on this document, and we recommend replacing the oil only via the measurement method. Using this measurement method, we can be assured that the correct amount of oil is being replaced inside the respective assemblies. [/font]
      Maintenance of front suspension MARZOCCHI  Æ  40 mm. ALUMINUM STANCHIONS
      1º – Disassemble the superior cap of each suspension leg.
      2º – Remove the spring.
      3º – With the suspension compressed to its maximum and verifying that there is no air remaining in the system, fill the suspension with oil.
      leaving an empty space of 160 mm. ± 2 mm.
      DENSITY OF OIL SAE 7,5
      4º – Re-assemble the system following the above procedure in reverse.
      Empty Space 160 mm.
      Oil level
      saludos. Quadtreropolar.
                       [/font]
    • #179312
      Aqui te dejo video explicativo (esta en inglés) .
    • #179313
      Gracias por la información;salton33,quadtreropolar y ourlyn.Lo vamos a probar.
